Problem uploading Favicon Image
Qi_40
Are there any specific requirements for the uploading of a Favicon Image?
I keep on uploading it but it is not showing. Not even in Profile Settings after uploading it.
I also do not get an error message when uploading it
S
Sonam
Hi Tim,
We request you to please check this video on Favicon Image - https://www.screenpresso.com/cloud/qNFed/
The option is working fine in your account therefore let us know if still face any issues with it.
Hope the above information helps.
Qi_40
Thanks you solved the problem.
Uploading a .ico file did not work. I uploaded a .jpg file and it worked.
