Same task is happening 2 times
gfreshmart
I'm using Router for splitting data based on column. My workflow was disables but today when I enabled this its doing the same task 2 times I'm getting splitted same data 2 times. So please tell me how can stop this without interrupting my workflow.
ArshilAhmad
Moderator
It looks like your workflow is receiving responses from two different Webhook URLs, resulting in it being executed twice. This issue commonly occurs when we click on Save & Send Test Request multiple times.
To resolve this problem, you must remove one of the Webhook URLs from your MailerLite account.
Alternatively, you can clone your workflow, connect it to your MailerLite account using a different Webhook URL, and set up your workflow in that manner. If you decide to clone, make sure to pause the current workflow.
