Sendfox triggers not working
Status: Closed · Asked by Jonathan Baillie Strong on · 0 views
When I set Sendfox up as a trigger for a new contact and click on save & send test request, it immediately responds with no data:
Hey @jonbstrong
We have tested the same at our end, the trigger step is working without any issues and capturing the response.
Please make sure that you have created a new contact on SendFox after integrating it with Pabbly Connect before selecting "Save and send test request."You might also try creating your workflow in incognito mode.
Please let me know if you still facing the same issue
For whatever reason, the old sendfox connection (API key) I set up is no longer working.
I set up a new connection and it works.
Any idea why this happens?
Hey @jonbstrong
It is possible that the reason you were facing the issue is that you may have revoked the Bearer token.
I never revoked anything!
Hey @jonbstrong
We kindly request you create a fresh connection with Sendfox and try to execute the task again. This will ensure that the workflow is working correctly and that the connection to Sendfox is established without any issues.
Also, I would like to tell you that the duration of a bearer token's validity depends upon the application you are using. Some applications may limit the validity of the token to a specific number of days, such as 30 or 60. After the expiration of this time period, you will need to create a new connection to continue using the workflow.
