SMTP by pabbly not listed in connection
teknikal
I seem to have not be able to find my SMTP connections. my settings for one of my connection has changed, however I can't seem to get to it to fix it.
Hey @teknikal
Can you please share the workflow URL once in which you have used the SMTP by Pabbly so that we can look into it?
ArshilAhmad
Moderator
If you want to make a new connection, you can do so from within your workflow as well.
As for why it's not showing up in your connection list, I will have this looked into by my technical team and get back to you.
We've implemented updates on our end and the connection will now accurately reflect the connection to the applications.
