Technical Assistance Required – SendFox, Gmail, Google Sheets & WhatsApp Auto-Reply Automation
Status: Closed · Asked by Anjali koli on · 0 views
Sidharth Parmar — Question ·
Hi Pabbly Support Team,
I need your technical assistance in setting up a complete email marketing reply automation using SendFox, Gmail, Google Sheets, and Pabbly Connect.
We run email marketing campaigns across multiple industries through SendFox, and I want the entire reply management process to work automatically without manual intervention.
1. Our Current Email Setup
  • Email Marketing Platform: SendFox
  • Campaign Sending Email: [email hidden]
  • Reply-To Email: [email hidden]
  • Incoming Replies: Gmail ([email hidden])
We send campaigns to different industry-specific contact lists, and all replies are received in our Gmail inbox.
2. Automation Requirements
A. Automatically Sync SendFox Campaign Data to Google Sheets
Whenever a new SendFox campaign is sent, I want Pabbly to automatically:
  • Fetch the Campaign ID, Subject, and Sending Date.
  • Fetch all actual recipient email IDs through the SendFox API.
  • Store the campaign details and individual recipient records in Google Sheets.
  • Avoid duplicate entries.
  • Handle different campaigns and industries automatically.
I do not want to manually export CSV files or update Google Sheets after every campaign.
B. Automatically Detect Email Marketing Replies
Whenever an email arrives at [email hidden], the workflow should:
  • Identify whether it is a reply to one of our SendFox campaigns.
  • Verify the sender against the campaign recipient records.
  • Exclude unrelated emails received in Gmail.
  • Work without manually applying Gmail labels.
C. Automatically Reply to Interested Prospects
If a prospect replies with positive intent, such as:
"Yes", "Interested", "Send details", "Tell me more", "Let's connect", etc.
Pabbly should automatically send the following fixed email in the same email conversation/thread:
Thank you for your response and interest.
I'd be happy to understand your business goals, discuss your current marketing challenges, and explore how we can help you achieve better results.
Please book a convenient time for a quick discussion here:
https://calendly.com/climbnrise-support/45-minute-growth-strategy-call-ind
Looking forward to connecting with you.
Best regards,
Sidharth Parmar
Founder
ClimbNRise Digital Marketing Pvt. Ltd.
We do not want to use AI-generated replies. The response should remain fixed.
The automation should also avoid responding to negative replies, unsubscribe requests, and quoted text that contains positive keywords.
D. WhatsApp Notification for Every Campaign Reply
Whenever any prospect replies to a SendFox campaign, I want an automatic WhatsApp notification containing:
  • Prospect Name (if available)
  • Prospect Email ID
  • Campaign Subject
  • Prospect's Reply
  • Whether the fixed auto-reply was sent
This alert should be sent even if the prospect's reply is not positive.
We already use Pabbly Connect and have experience with WhatsApp automation through Chatflow.
E. Response Time and Duplicate Prevention
Ideally, positive replies should receive the fixed response within 5 minutes, including outside business hours.
The workflow should also prevent duplicate auto-replies, repeated responses in the same thread, and email loops.
3. What We Have Already Configured
We have completed the following initial setup:
  1. Connected Gmail with the New Email trigger and successfully captured incoming messages, sender details, subject, email body, Message ID, and Thread ID.
  2. Connected SendFox using a Personal Access Token.
  3. Successfully fetched campaign details through the SendFox API.
  4. Successfully retrieved recipient-level engagement data, including email IDs, contact IDs, and sending timestamps.
Example Campaign ID: 3062235
For this campaign, SendFox shows 166 sent emails, and the non-openers API returned 164 recipient records. We are also exploring the openers endpoint to retrieve the remaining records.
4. Assistance Required
Could your technical team please guide us on:
  1. The correct architecture for these workflows in Pabbly Connect.
  2. How to automatically sync all sent-recipient records from SendFox to Google Sheets.
  3. How to handle API pagination, arrays, iterators, and duplicate checks.
  4. How to accurately identify incoming SendFox campaign replies without Gmail labels.
  5. How to extract only the latest reply text, excluding quoted email history.
  6. How to configure keyword-based routing and reply within the same Gmail thread.
  7. How to integrate WhatsApp notifications using Pabbly Chatflow.
  8. Whether a response time of 5 minutes or less is technically achievable with your Gmail trigger.
We would appreciate step-by-step technical assistance or a screen-sharing session to help us implement and test this complete automation.
Our objective is to have a reliable, fully automated email marketing response system without manual campaign data updates.
Looking forward to your support.
Best regards,
Sidharth Parmar
Founder
[email hidden]
Pabbly Support — Reply ·
Hi Sidharth,
Thank you for sharing the detailed information about your requirements and the setup you have completed so far.
Please note that our support team assists with technical issues related to Pabbly, such as workflows not running as expected, execution errors, or other product-related issues. However, we do not provide end-to-end workflow setup or step-by-step implementation assistance from scratch.
For guidance on configuring your automation, you can explore our tutorials on the https://www.youtube.com/@Pabbly.
Alternatively, you can connect with independent Pabbly experts and consultants through our https://forum.pabbly.com/threads/pabbly-connect-experts-and-consultants.36509. They may be able to assist you with the complete setup and implementation of your requirements.
If you encounter any technical issues or errors while building or running your workflows, feel free to reach out to our support team. We’ll be happy to help you troubleshoot the issue.
Vinay Jain
🌐 Pabbly.comSignature image
Sidharth Parmar — Reply ·
A quick correction to my previous email.
I accidentally shared the CNR Call Booking Workflow link instead of the Email Marketing Automation Workflow link.
Please disregard the previously shared workflow link.
Correct Email Marketing Workflow Link:
https://connect.pabbly.com/v2/app/workflow/share/D0cFN1UCCWoETgRuVDENKgEVVVEGXAI_VE0GFFxTBn4HXVY9UxJcNgtHByUHVFMyB05QOlYKV20JHVdTA1UEd1JLBytTUFYsBEkGfQRBWGsPUQUtVTQ#
Kindly refer to this workflow for the automation setup and technical assistance requested in my previous email.
Apologies for the confusion.
Best regards,
Sidharth Parmar
Founder
Hi Sidharth,
Thank you for sharing the correct workflow link. No worries about the confusion.
We’ve noted the updated Email Marketing Automation Workflow link. As mentioned earlier, our support team can assist with troubleshooting technical issues related to Pabbly Connect, such as workflow execution errors or unexpected behavior. However, we do not provide end-to-end workflow setup or implementation assistance.
If you encounter any specific technical issue while configuring or running the workflow, please share the details with us, and we’ll be happy to review and assist you accordingly.
For complete setup and implementation guidance, you can also connect with independent Pabbly experts through our https://forum.pabbly.com/threads/pabbly-connect-experts-and-consultants.36509
Vinay Jain
Hi Sidharth,
Just following up to check if you have any specific technical issues with your workflow. If so, please share the details, and we’ll be happy to assist you.
Vinay Jain
Hi Sidharth,
We’re following up on our previous message regarding your query. As we haven’t received a response, this will be our last follow-up, and the thread will be closed automatically.
If you still need assistance, you can email us again at support@pabbly.com to raise your concern.
We would also greatly appreciate it if you could share your feedback on your support experience using the following link: https://bit.ly/3V2Pjia
Vinay Jain
