ThriveCart Recurring Subscription For Certain Products
Status: Closed · Asked by nickjames on · 0 views
I am looking to find out how to trigger actions only when a ThriveCart subscription is made for a certain product.
How do you set a filter for this so that the system only triggers for certain products only. How can I find this?
Thank you
Hi @nickjames,
You can use 'ThriveCart: Product Purchase' as your trigger step and select the specific product that will trigger the workflow upon purchase.
Thank you. It was more about the pabbly filters that I was looking for... and the ability to CLONE the workflow without having to re-map the data.
Hello @nickjames
To learn about filters in Pabbly please refer to this tutorial -
youtube.com/watch v=RVoCVvcdk4I
Also, if you need any assistance regarding filters please let us know.
Can you elaborate a bit more on this Because as we clone a workflow it depends on the trigger step if we require remapping or not.
