Trigger for pabbly connect with specific button in funnel (clickfunnel classic)
Status: Closed · Asked by The_One_Piece_Is_Real on · 0 views
Hi, how can I enable TRIGGER for pabbly connect, when a specific button is pressed in clickfunnel (clickfunnel classic)?
Hi @The_One_Piece_Is_Real,
If ClickFunnels has a trigger event that can be activated upon the press of a button, you can use Webhook by Pabbly to connect with your ClickFunnels account and fetch the details.
Hi @The_One_Piece_Is_Real,If ClickFunnels has a trigger event that can be activated upon the press of a button, you can use Webhook by Pabbly to connect with your ClickFunnels account and fetch the details.
Thank you Arshil, I am not so good with software.
Could you give me a more detailed example for clickfunnel classic?
The first part of the video shared below shows how to connect with your ClickFunnels account. In the video, the Event Type is 'Contact Created.' If ClickFunnels has an event type triggered by clicking a button, you can choose that. You would need to get in touch with the ClickFunnels support team to find out if they have that event type or not.
Excuse me @@ArshilAhmad, is there a way for you to develop this integration better and allow you to select the funnel and the specific step within the funnel?
In Zapier it can be done, I attached a screenshot. I'm waiting for the answer,
If you want 'New Contact Activity' action event to be added to Clickfunnels you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Integration-Request
Our integrations team will look into your request and, if possible, add the desired endpoint to Pabbly Connect.
