Webhook Not Refreshing- Stale
Status: Closed · Asked by Peter Pappas on · 0 views
Peter Pappas — Question ·
Asana trigger "Updated Task in a Project" (workflow "CC Episodes - Delete FB Live on Card Complete") registers its webhook and receives events (task history shows runs), but the trigger panel never shows a sample response, so later steps say "No fields available in this step." "Save & Send Test Request" now returns Asana's "Duplicated webhook" error. Can you clear the stale webhook on your side or load a sample from the last execution so I can map fields?
Pabbly Support — Reply ·
Hello Peter,
Thank you for reaching out and providing the setup details and authorization.
The “Duplicated webhook” error indicates that Asana may already have a webhook registered for the trigger, preventing a new one from being created. Since the test payload has not been captured, the downstream action steps cannot detect the required fields.
To resolve this, please follow these steps:
  1. Clone the workflow: From your Pabbly Connect dashboard, click the three-dot menu next to the workflow and select Clone.
  2. Turn off/inactive the original workflow: This helps prevent both workflows from processing the same events.
  3. Re-capture the webhook response: Open the cloned workflow, access the Asana trigger, and click Re-Capture Webhook Response instead of Save & Send Test Request.
  4. Trigger a real event: Make a test update to a task in the connected Asana project so the trigger can capture the event payload.
  5. Verify the data mapping: Once the response is captured, check and update the field mappings in the downstream action steps, save the workflow, and turn it on.
If the issue persists, please let us know so that our technical team can review the workflow and investigate accordingly.
Shekh Dilshekh
Customer Support Specialist
🌐 Pabbly.com
🎉Black Friday Early AccessSignature image
Peter Pappas — Reply ·
Followed your steps exactly: cloned the workflow, kept the original inactive, turned the clone ON (required to capture), clicked only "Re-Capture Webhook Response," then made two real updates to a task in the Asana project. The clone waited over a minute and captured nothing. It looks like the clone has a new webhook URL that Asana was never told about, since only "Save & Send Test Request" registers it, and that's what returns "Duplicated webhook." Can your technical team either delete the existing Asana webhook registration for this project so Save & Send works again, or load a sample from the original workflow's last execution (task history shows several runs)?
Hello Peter,
We appreciate you taking the time to try the suggested troubleshooting steps.
After reviewing the issue on our end, we have identified the following findings:
  1. Further Investigation Required: The behavior does not appear to be a general issue with Pabbly Connect, as we verified that the same trigger works as expected in one workflow but encounters errors in another. This suggests that the issue may be related to an Asana-side limitation.
  2. Error Documentation Review: We also reviewed Asana’s official documentation provided within the error response, but unfortunately, we could not find any information that clearly explains the error.
To investigate this further, we have escalated the issue to our technical team for a detailed review. We will keep you informed and get back to you as soon as we receive an update.
We appreciate your patience and understanding while our team looks into this.
Shekh Dilshekh
🌐 Pabbly.com
Hello Peter,
We have an update regarding the issue you reported with the Asana trigger.
Our technical team has cloned your workflow and configured the trigger for further testing. During testing, the webhook was registered successfully, and no duplicate errors were encountered.
You can review the cloned workflow using the link below:
CLONE - [CC Episodes - Delete FB Live on Card Complete]
Since the trigger is working as expected in the cloned workflow, we request you to review it and compare its configuration with your original workflow to see if there are any differences.
Please check the same on your end and let us know whether the issue persists in your original workflow. Based on your findings, we will be happy to assist you further.
Thank you for your patience and cooperation.
Shekh Dilshekh
🌐 Pabbly.com
Hello Peter,
We are following up regarding the Asana trigger issue you reported earlier. As shared previously, our technical team tested the trigger in a cloned workflow, where the webhook was registered successfully without any duplicate errors.
We had requested you to review the cloned workflow and compare its configuration with your original workflow to check for any differences. We are currently awaiting your update on whether the issue persists in your original workflow.
Kindly check the same at your convenience and share your findings so we can proceed with the necessary steps to assist you further.
We look forward to your response.
Shekh Dilshekh
🌐 Pabbly.com
Hello Peter,
As shared earlier, our technical team tested the trigger in a cloned workflow and confirmed that the webhook was registered successfully without any duplicate errors. We had shared the cloned workflow with you for comparison and requested you to verify whether the issue persists in your original workflow.
As we have not received any further updates regarding the Asana trigger issue, we are closing this ticket for now.
If you are still experiencing the issue or require further assistance, please feel free to reply to this email with your findings. We will be happy to review the matter further.
We would also greatly appreciate it if you could share your feedback on your support experience using the following link: https://bit.ly/3V2Pjia
Thank you for choosing Pabbly!
Shekh Dilshekh
🌐 Pabbly.com
