why delay by pabbly not working with iterator
i have a workflow to send whatsapp message from iterator i add at the end of workflow delay for 1 minute but its run only one time if i remove delay by pabbly then its keep working
Pabbly
Administrator
As of now, the delay module does not work with the Iterator module. We are aware of this scenario and will be updating it in the near future so that both modules can work simunteneously. Thanks!
Fagun Shah
ok what about if i create schedule rule then delay dose the delay module can work with schedule module ?
Yes it should work that way.
Also another thing you can do is this,
Instead of placing a delay module after iteratir, create a new workflow with webhook as a trigger and place delay module there.
You can send data from workflow 1 to workflow 2's webhook using API module inside pabbly connect.
