    🔥 Pabbly Subscription Billing One Time Plan for $149 (🏆Lifetime Access) - View offer
WooCommerce edit total
dylanj
Firstly, great product, I find it so much better than Zapier so far!! However, I have ran into an issue. The issue with Pabbly Connect is when 'creating an order' in Woocommerce, it does not have a field for the subtotal and total. I'd like to fill this dynamically and map a field to it.
Pabbly seems to use the product ID to get details about the product including price and calculates the total I guess. This is kinda cool, but not for my use case.
See I'm using woocommerce subscriptions and offering a trial period for subs, and how it works in Woocommerce, when a subscription is created a parent order is created, and if the subscription has a trial period, that initial parent order will have a total and subtotal of $0.00. I'm finding it hard to figure out how to recreate this. It always sets the total as the product price.
Another feature that I could do in Zapier but doesn't seem possible with Pabbly is adding custom meta fields to a new customer or custom post meta to a new order. Am I missing something or is this not possible?
Arshita
Moderator
Hey @dylanj
I kindly request you to use the "WooCommerce : Create an Order (with Line Items)" action step within your workflow to include the subtotal and total values. This will allow you to easily add these values within your workflow.
Additionally, this action step provides a meta field which enables you to customize your workflow as per your specific needs.
