workflow is not running
Prachi SND
I have created a workflow in which when an order is updated in woo commerce and its status is completed it will be entered in google sheets. using the product id of the completed order, I have to send WhatsApp message of the installation link with the product image which is mentioned in another Google sheet. I want pabbly to lookup product id and send the required link and image to the targeted person with whatsapp AI sensy. but my flow is not working.
ArshilAhmad
Moderator
Hey @Prachi SND,
Email: [email protected]
ArshilAhmad
Moderator
It seems that you have entered/mapped incorrect data in the Lookup Column(s) field. Please enter/map the column as it is given in the help text and try again.
Prachi SND
my work is to send messages with installation links to the customers. 1 sheet have all data of customers and second is of links. common thing between sheets are their product IDs, how to I initiate this automation.
And one more issue is I have images of product in my laptop how do I send message with images when I insert drive image link in link sheets
ArshilAhmad
Moderator
can you do this you are now a team member
Since I do not know the columns whose data you want to capture, I cannot make this change for you.
Please watch the attached video below to understand how to use the Google Sheets 'Lookup Spreadsheet Rows' action event.
I would suggest that you seek help from an automation expert who can assist you in setting up this workflow according to your use case.
