Workflow not saved?
linkport
We have the workflow with ID IjU3NmMwNTY5MDYzMzA0MzA1MjY4NTUzNiI_3D_pc
This workflow contains 4 steps but only the first 2 are being executed. There are no errors. It just seems Pabbly is executing an old workflow even if we have extended the amount of steps.
You can see the amount of steps published in the workflow vs the amount of steps in the history log.
Can you please check?
A
Arshita
Hey @linkport
As I can check, you have put the delay of 36 Hours in the delay action step in your workflow so it will send the Whatsapp message when the delay gets completed.
Please wait for 36 hours and check.
Let me know if you face any kind of issues.
linkport
Hi @Arshita ,
Thanks for the help. I thought the history shows all the steps of the workflow and the current step of each process, but I get what you say.
Thanks again.
Pablo
