After Updating Flow w/ Depreciated Field Flow No Long Works
I had a flow with a depreciated field. It was Google Calendar to Notion where the page was depreciated. Updated and ran a test which was successful (as I can see it in the database) but it's still not working.
Supreme
Hey @jessicadanielle
Could you please share the name of the workflow in which you are having such difficulty? Also, kindly try remapping all the fields in your workflows action step once.
The workflow is Test Calendar to Notion. I removed and readded the integration with Notion, then recreated it from scratch and it sends a test response okay.
Supreme
Please try the " Google Calendar: New Event (Beta)" trigger event in your workflow. Kindly make a few test submissions and let us know how it is working for you.
