Airtime and Mobile data top up by Pabbly
Moisecom
Is there a way to get automation with Pabbly API to connect Telecom Operator API with a given Form to collect data for "AIRTIME AND MOBILE DATA Top up". ? Lets take example with AIRTEL which is present in my country. Thank you
Pabbly
Administrator
Would you mind elaborating more on the use case you're looking forward to automating? Like if somebody fill the form, you wish to show certain results in the output
Moisecom
Thank you,
If someone fill the form (Jotform or another like Pabbly form Builder), his Airtime or Data wallet from Airtel will receive the amount filled in the form's related field. Of course, there will be a payment step before the form is sent. So the form POST data to AIRTEL API which fill the customer wallet. I am not tech ingineer and i am asking for my Business project relating to top up Mobile Telecom Wallets. Is the following turorial in line with my question?
PabblyMember3
Seems it is possible if Airtel has such API to update the wallet details, you can use Pabbly Form Builder with Payment option enabled and get the data received in Pabbly Connect workflow then, using the API module, you can use the Airtel API to achieve that.
Moisecom
Thank you Naveen, but dont i think i can do it by myself and i will probably need help from Pabbly. Does pabbly provide staff for this direct support?
