Automation is not working
Status: Closed · Asked by blockman on · 0 views
blockman — Question ·
Task History ID: IjU3NjYwNTZmMDYzNjA0MzQ1MjZmNTUzZDUxMzYi_pc
hi i have a Reply Tweet automation it was working last month, but now its just stopped, and only work when i manually process it and then it just never work.
Hi @blockman,
It seems like you have captured the latest feed in the trigger step of your workflow setup. Please wait for some time until a new feed is generated. If it doesn't trigger your workflow, do let us know without clicking on the 'Save & Send Test Request' button.
blockman — Reply ·
i have been waiting for 5 days as i said it only works when i manually do it then no you can check history it has no history since last 7 days
Please allow us some time to look into this concern. We will get back to you shortly.
blockman — Reply ·
any update as you have seen it did not worked for last 24hrs
Our team is looking into this issue. Please allow us some more time. We will get back to you as soon as we have any updates.
blockman — Reply ·
sir its been 1 month i am not using services any solution
Our technical team is currently investigating this issue. Please allow us some time, and we will get back to you as soon as it is resolved.
Hello @blockman,
The issue has been resolved by our team. Please try using the RSS trigger on your end and let us know if it works fine for you.
