Blog ID is not shown even after connecting through Blogger. Please FIX it ASAP. Or Give instruction to map it manually
khelcorner
Your Task History ID
Not Found
Hey @khelcorner
As we can see that the name of the blogs is showing now. Please make sure that you have made the correct connection with the correct Blogger account.
Can you please check your connection once from your workflow once and then try.
