Blue Not Showing Custom Field
Anupam
Bitform - Blue Custom Fields
I'm really close to getting this work but need another set of eyes. I have the integration from Bitform to Blue set up.
I am pulling the custom field with the step "Get Todo Custom Fields".
But the last step of actually assigning the custom field is where I'm stumped. Set ToDo Single Custom Field
I am using the Custom Field Single Select Option ID.
The custom field is called Priority and there are four options to select.
When I select the ID and test it - the record in Blue updates the Priority Field but it updates based on what I selected - not what the user selects.
Here's a video showing my process / steps.
What do I need to select or what steps do I need to add to update the Priority of the Record to what the user who filled out the form actually selected?
Sorry to barge in your thread. I too am a user like you facing integration issues with Blue and during my research found your thread. Thank you for making your thread public so that people like me can benefit.
Having said above, i want to ask you when you can directly use "Set ToDo Single Custom field", why would you need "GetToDo custom field"? If the input that you are trying to push from bitfom to blue is just a single field called "Priority", it can be directly done by "Set ToDo Single Custom field" without needing "Get ToDo custom field". After that whether you fill the bitform or the user fills the bitform, it does not matter for pabbly. The data that is in "Priority" field of bitform should automatically go to the "Priority" field of Blue.
jkriggs
My understanding is that you have to "Get" the custom field ID first and then you can "Set" it.
Anupam
Could you make it work? Isn't blue integration too complicated? I am facing issues at "Position" field in "Create ToDo records"
Anupam
Were you able to make Create ToDo Record field to work? Are default fields passing through? Looks like instead of pabbly, this is limitation with blue.cc because their api is not flexible with custom fields.
