Calendly and clickup
Steven
I'm trying to create a task on clickup when a calendly invite is created however it seems that the date and the time isn't there?
Supreme
Hey @Steven
You can check for the Start and End Time in the trigger response of Calendly.
Supreme
Hey @Steven
Because you need to pass the date time in the TimeStamp format in the Start Date fields.
Kindly refer to the following screenshot for the same.
Supreme
Hey @Steven
As we can see from your workflow, you are still not passing the date time in the "Start Date" in TimeStamp format.
Though we have converted the time for you and mapped it accordingly. Kindly review your workflow once and then try again.
