ChatGPT o1 model - how to choose?
Status: Closed · Asked by El_Lorenzo on · 0 views
I am totally new to automation, and I have been comparing Make.com, Zapier and Pabbly.
For a specific task, I need the o1 model. In Make.com where the app is called exactly the same, but I can choose from so many models, and I am just wondering why these models are not available in Pabbly or am I doing something wrong?
In regard to the Lifetime subscription I would like to buy, I want to make sure, that I can use the newer models of ChatGPT as well and not just the 4o model.
Thank you!
I am totally new to automation, and I have been comparing Make.com, Zapier and Pabbly.For a specific task, I need the o1 model. In Make.com where the app is called exactly the same, but I can choose from so many models, and I am just wondering why these models are not available in Pabbly or am I doing something wrong
Thank you!
Hello @El_Lorenzo ,
Though o1 Model is not available in pabbly but you can use that model by turn on map button and write it down by your own.
Please refer below screenshot for reference.
Hello @El_Lorenzo ,
Thank you so much!!!! That helped alot.
Your Welcome
