ConvertKit => ThriveCart Learn
sacha
Hi!
I am trying to set up a workflow that enrolls subscribers in a ThriveCart Learn course when they sign up to my email list using a ConvertKit form, but I can't figure out how to do it using webhooks and ThriveCart's API. I was able to do this in Zapier previously, but I'm not sure whether this is something I can do using Pabbly as I can't figure out how to get access to the webhooks app in Pabbly… Has anyone done this successfully?
Thank you!
ArshilAhmad
Moderator
Hi @sacha,
We do have Webhook by Pabbly Trigger application, which you can use to set up webhook-based workflows.
But for ConvertKit, we already have a dedicated trigger application. Is there a reason why you are not using this dedicated trigger step instead?
sacha
Thank you for your response! I actually figured it out in the end… I had to choose "API" for the second step in the workflow and connect it to ThriveCart Learn that way. I did use the dedicated application for ConvertKit in the first step, but ThriveCart Learn doesn't natively provide the function to sign people up to their courses without using their API. And when I set it up in Zapier, I had to use their webhooks app, which is what was confusing me. But it's all sorted now, thank you!
