Create Users in High Level / LeadConnector - Wrong SubAccount Location
GW3
Your Task History ID
IjU3NjIwNTY1MDYzNjA0MzU1MjZlNTUzMzUxMzM1MTY0NTQzMiI_3D_pc
We have this workflow setup to find the location ID in Monday and then Add the users to that location, when a status changes in Monday.
It worked on the original setup, but I just ran it with a client and it loaded them to a different location ID. Do you know what may be causing this?
The location it added them to is not inside of the Monday.com Item, so I'm confused how it got that information.
Here is the workflow https://connect.pabbly.com/workflow...bBWEPGwoOUwUAcwEYBDhSUQd9WxYGfQ1UXW4NUwUtBGU#
Supreme
Hey @GW3
Regarding your workflow can you please try the action step Get Location by Location Id action step in place of the Search location by Campany Id action step?
  • Like
Reactions: GW3
