facing problem in elementor to close
Status: Closed · Asked by NBFC Advisory on · 0 views
NBFC Advisory — Question ·
I'm not facing any issue to connect elementor to close crm while debugging. but after saving the workflow my webhook throwing error and my elementor contact form entry not pushing to close.
@Pabbly support please give me support for the same
Hey @nbfcadvisory
Can you please share the workflow URL once in which you are using the same?
Hey @nbfcadvisory
Can you please try capturing the webhook response once and then try the complete workflow?
Also, do check whether the webhook URL is still intact in your WordPress or not.
