Carlos Melo
Hi guys,
That's it, filter of route does not display previous workflow steps as option in the Select Label if I try to edit it. It only displays future steps.
Filter step only shows previous steps in the Select Label field for conditionals when I'm building the workflow for the first time, but it doesn't show them if I want to add new conditions in the same filter after it is ready and tested once.
Please check image below.
So,
This flow is too big and labor intensive for me to have to build it all over again just to be able to add data I need in the filter.
Is there a bug here or am I doing something wrong?
So,
