Gravity Forms - Save and Continue Webhook not working
Status: Closed · Asked by iamru on · 0 views
I have an issue where the Webhook functionality from Gravity Forms does not pull in the Save and Continue data (token and link) as a triggered event.
For instance, if someone submits a Gravity form, it triggers, but if someone only partially fills in the form and clicks "Save and Continue", then it doesn't get triggered.
This is an important step as many clients would not necessarily have the info to fully complete a form and thus would start the process with a Save and Continue.
How can I have the Save and Continue data pull through and trigger a Gravity Forms webhook?
Hello @iamru,
The trigger you are using is a descriptive webhook-based trigger(refer to the attached image) due to that the responses sent by the Trigger application aren't in our control. Regarding any difficulties faced with the data not getting received from descriptive webhook-based triggers, we recommend you contact their team(Gravity Forms Team in this case).
Although you can test the responses sent by their end using Webhook.site. Please refer to this tutorial to learn how to use webhook.site -
.Thanks.
It's a pity as Gravity Forms has a Zapier plugin that allows for this info, yet nothing like this is available for Pabbly.
Further to that, with Pabbly I cannot seem to check for updated MySQL rows and that it only allows me to check for new rows.
Again, this is something Zapier allows for.
Any ideas?
Currently, we don't have a trigger event that captures updated rows from MySQL. If you would like this trigger event to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Update-Existing-Application
Our integrations team will review your request and, if possible, add the desired trigger event to Pabbly Connect.
