How to Connect Memberpress?
otherlife
I see that Memberpress is one of the supported apps, yet when I try to connect it within my workflow, it's not there. Please advise!
otherlife
Nevermind. Apparently, Memberpress can't be used within a workflow. It can only be used as a trigger. This is quite disappointing. lol Is there any way other than API to add it within a workflow?
Supreme
Hey @otherlife
In that, you can use API by Pabbly action step where you can design the API by yourself. You check for the API documentation from the Memberpress team.
You can also refer to our tutorial video on "API by Pabbly". Kindly try this at your end and let us know how it works for you.
Further, If you want to request for building up new integrations, please send us the request here and upvote it -
https://pabbly.hellonext.co/b/Integration-Request
