How to Connect PostgreSQL with Pabbly Connect
Table of Contents​
  1. Overview
  2. Important Security Requirement
  3. Before You Start (Prerequisites)
  4. Allow IP for Cloud-Hosted PostgreSQL
  5. Allow IP for Self-Hosted PostgreSQL
  6. Connect PostgreSQL in Pabbly Connect
  7. PostgreSQL Connection Fields Explained
  8. Available PostgreSQL Actions in Pabbly Connect
  9. Test the Connection
  10. Common Problems & Easy Fixes
  11. Final Checklist
  12. Completion Status
1. Overview​
Pabbly Connect allows you to connect your PostgreSQL database and automate tasks like inserting, updating, fetching, and deleting database records — without writing code.
To make this work, your PostgreSQL server must allow access from Pabbly Connect’s integration server.
2. Important Security Requirement​
PostgreSQL blocks unknown servers by default.
To connect PostgreSQL with Pabbly Connect, you must allow the following IP address:
Pabbly Integration Server IP: 157.180.81.74
⚠️ If this IP is not allowed, PostgreSQL connection will fail.
3. Before You Start (Prerequisites)​
Make sure you have:
  • A running PostgreSQL database
  • Database details:
    • Host
    • Port (usually 5432)
    • Database name
    • Username & password
  • Access to your server or cloud provider
  • Access to Pabbly Connect
4. Allow IP for Cloud-Hosted PostgreSQL​
(AWS RDS, Supabase, Neon, Render, Azure, GCP, etc.)
  1. Log in to your cloud provider.
  2. Open your PostgreSQL database settings.
  3. Go to Security / Firewall / Network Access.
  4. Allow this IP address: 157.180.81.74
  5. Ensure PostgreSQL port (5432) is allowed.
  6. Save the changes.
✅ Cloud PostgreSQL is now accessible from Pabbly Connect.
5. Allow IP for Self-Hosted PostgreSQL​
(Server / VM / On-Premise)
5.1 Allow IP in Server Firewall​
Allow incoming traffic from:
157.180.81.74
(This is usually done by your system administrator.)
5.2 Allow IP in PostgreSQL Settings​
  1. Open the pg_hba.conf file.
  2. Add this line:
    host all all 157.180.81.74/32 md5
  3. Save the file.
  4. Restart or reload PostgreSQL.
✅ PostgreSQL is now ready to connect.
6. Connect PostgreSQL in Pabbly Connect​
  1. Log in to Pabbly Connect.
  2. Create a new workflow or open an existing one.
  3. Click Add Action → Select PostgreSQL (Server).
  4. Click Add New Connection.
  5. Fill in the connection details (explained below).
  6. Click Save.
✅ Connection status should show Connected.
7. PostgreSQL Connection Fields Explained​
While creating the connection, you will see the following fields:
New Connection Name​
Give a name to identify this connection.
Example: Production PostgreSQL
Username​
Enter your PostgreSQL database username.
Example: postgres, admin, db_user
Password​
Enter the password for the above username.
Database Host​
Enter your PostgreSQL server hostname.
Examples:
  • db.example.com
  • xyz.supabase.co
  • your-db.rds.amazonaws.com
⚠️ localhost or 127.0.0.1 will NOT work.
Database Name​
Enter the name of the database you want to connect to.
Example: prod_db, app_data
Database Port​
Enter the PostgreSQL port number.
Default: 5432
(Use a different port only if your server uses one.)
SSL Required​
Choose whether SSL is required.
  • Yes → Recommended for most cloud databases
  • No → Only for local or internal servers
ℹ️ Most cloud PostgreSQL providers require SSL.
8. Available PostgreSQL Actions in Pabbly Connect​
Once connected, you can use the following PostgreSQL actions:
Insert Row​
Adds a new row (record) into a table.
Update Row​
Updates existing data in a table based on conditions.
Get Rows​
Fetches data from a table based on filters or conditions.
Delete Rows​
Deletes one or more rows from a table.
⚠️ Use carefully, as deleted data cannot be recovered.
Run SQL Query​
Run a custom SQL query directly on your database.
Examples:
  • SELECT queries
  • JOIN queries
  • Advanced custom logic
⚠️ Recommended for advanced users.
9. Test the Connection​
  1. Select any PostgreSQL action.
  2. Click Save & Send Test Request.
  3. Check the response.
If data is returned or affected successfully, the setup is complete.
10. Common Problems & Easy Fixes​
Connection Failed​
  • Check IP 157.180.81.74 is allowed
  • Verify host and port
  • Ensure PostgreSQL is running
Authentication Error​
  • Recheck username and password
  • Ensure user has database access
Timeout Error​
  • Wait a few minutes after allowing IP
  • Restart PostgreSQL
11. Final Checklist​
✔ PostgreSQL is running
✔ Pabbly IP allowed
✔ Firewall configured
✔ Database credentials verified
✔ Connection tested successfully
✔ Workflow enabled
12. Completion Status​
🎉 PostgreSQL is successfully connected with Pabbly Connect.
You can now automate your database operations smoothly and securely.
