How to set up filter to prevent duplicates
slade84
I continue to get duplicates due to Pabbly's webhook firing multiple times, which is causing issues with my lead flow.
I want to create a stop filter where if the email already exists in Airtable, the workflow will stop so that I don't get duplicate entries.
Can you tell me if I've set it up correctly (see attached)?
The workflow name is Formaloo --> Sheets --> Airtable
Ryan
Yes, the filter action step seems fine, since the current situation of the filter is not true but in real-time execution, your workflow will perform as expected.
And before that, you need to use the Search Record action step.
Hey @Oleksandr
Can you share the name of the workflow once you have the automation? So that we can look into it and can guide you accordingly.
