I am already on a Unlimited Pabbly plus plan - Unable to add subscribers more than 100
Status: Closed · Asked by Abhishek Gupta on · 0 views
Abhishek Gupta — Question ·
Need solution asap
Pabbly Support — Reply ·
Hello Abhishek,
As per our checks, we found that the subscriber allocation on your dashboard is currently set to 100, which is why you are unable to add more subscribers.
To resolve this, please click on the 3 dots (⋮) and select Allocate Subscribers.
Once the subscriber allocation is increased, you should be able to add more subscribers.
Please let us know if you face any issues.
Naman Bansod
Customer Support Specialist
🌐 Pabbly.com
👉 Rate your support
Abhishek Gupta — Reply ·
Name & Address is revealed in snapshot you shared, Kindly make this private asap or delete this thread
Hello Abhishek,
This is a public forum, so the post cannot be made private. However, we have edited the response as requested.
Please check and let us know if you face any further issues or need any assistance. We’re here to help.
Also, if you are satisfied with the support provided, we would appreciate it if you could take a moment to share your feedback on Trustpilot. Your feedback helps us improve our support.
Share your feedback on Trustpilot
Naman Bansod
🌐 Pabbly.com
👉 Rate your support
