I have a problem with copying posts from fb to google my business
max4321
hello I have a problem with downloading posts from fb. I don't want to download posts from fb from one fb fanpage. I have access to several fanpages on fb and I don't want to download posts to one of them. What could be the reason?
Hey @max4321
Could you please briefly elaborate on your query once and let us know about the posts which you don't want to manage?
max4321
Hey @max4321
For some reason, pabbly is not getting me new fb posts from one of the fanpages. I get a response message like in the screenshot. I used to have a similar problem. then it was enough to define the number of downloaded posts.
Hey @max4321
Can you please check that you have all the permission access to your desired pages from Facebook while connecting your account?
Also kindly give full access to the Pabbly Connect app to view and manage pages in your Facebook account is not provided.
You need to make sure all the permission are enabled for the pages which you're looking forward to integrating in Pabbly Connect -
max4321
Hey @max4321
ok, i have but it didn't help
Hey @max4321
Kindly try removing the Pabbly app from your Facebook account and then try reconnecting your Facebook account.
Then you need to make sure all the permission is enabled for the pages which you're looking forward to.
Also, record a short video on how you are granting permission to the particular page while connecting to your Facebook trigger event. So that we can look into it and guide you accordingly.
max4321
Hey @max4321
Is there any other way to do it? all my automations use the same administrative account on fb and there are a lot of them. how do i have to check them all or because after this operation one may stop working.
Hey @max4321
There is no other way to configure the Facebook Page, you need to check it from your administrative account and check the respective page to send the data to the Facebook trigger event.
Moreover, you can again try re-connecting the FB page by making a new connection while connecting your account make sure that you have selected all the necessary pages at once.
Note - Kindly log out to your Facebook account before adding a new connection.
Hey @max4321
We tried to access your respective page in your account and it is capturing the webhook response completely.
Kindly reconnect the action step again and refresh the access token too.
max4321
Hey @max4321
for the moment I have solved it so that posts from fb are downloaded by another automation forwards to pabbly and pabbly in google my business. I'll come back to it later
