Integrate with Aisleplanner
Evently
An integration with Aisleplanner is all I need to come completely away from Zapier. Is this in the roadmap or could it be? The same triggers and actions as zapier would be awesome.
I was looking for a connection request section of the forum but couldn't find one.
ArshilAhmad
Moderator
Hi @Evently,
If you wish to have the Aisle Planner application added to Pabbly Connect, you can submit your request on our dedicated platform at https://pabbly.hellonext.co/.
Our development team will review your request and, if possible, add the desired application to Pabbly Connect.
You can also try using Webhook and API by Pabbly module to connect with this application if it supports webhooks and REST API.
