MailerLite Workflow is not working
Hi, when i try to connect MailerLite, i am unable to select the dynamic fields.
I've encountered this same issue before (with another workflow) and someone from Pabbly had to make some adjustments to the backend to fix this.
Can you assist?
Supreme
Hey @yang_yang74
Kindly try enabling the mapping button and then map the email address in the Subscriber Email field which will dynamically create or update the subscriber accordingly.
