Pabbly and highlevel
Dustin H
How can I connect gohighlevel and pabbly? I do not understand that instructions because its for the old layout of highlevel. I want an apointtment setting as an trigger and then send a confirmation via WhatsApp. Thank you very much. Sincerly, Dustin
Arshita
Moderator
Hello @Dustin H
To establish a connection between GoHighLevel and Pabbly Connect, please refer to the related video below. The video provides step-by-step instructions on how to set up GoHighLevel, enabling you to understand the process better.
(Watch the first part of the videos)
Do let us know if you get stuck in any step, so we can check it for you.
Hello @Dustin H
I'm attempting to create GHL locations, as per your previously video embedded video.
On the Workflow Action test, i'm receiving a response "Msg" "Unauthorized"
HighLevel appears to have a new Auth 2.0 process.
Please see:
1. https://help.gohighlevel.com/support/solutions/articles/48001060529-highlevel-api
2. https://highlevel.stoplight.io/docs/integrations/0443d7d1a4bd0-api-2-0-overview
3. https://highlevel.stoplight.io/docs/integrations/7cfc7963eda7c-create-location
I've just:
1. created a HighLevel Developer's account at https://marketplace.gohighlevel.com/
2. Created an Agency type app
3. Create Client ID and Secret
4. added "locations.write" scope
Now I'm not sure if I need to add a redirect URI or Webhook in the new GHL app or not...
How to auto-create GoHighLevel sub-accounts now?
Do we need authorization headers or something for Pabbly to send an action?
Does Pabbly HighLevel integration need upgrade?
Would we use a Pabbly API action instead of HighLevel (legacy)?
Thanks for your help!
Supreme
Hey @skyfreshsingh
We recommend you use the "Create Location" action step instead of creating the API by Pabbly action step in your workflow.
Kindly give it a try and let us know if that works.
