Pabbly receiving wrong FB lead ads data! [very weird thing!!!]
Hi everyone! I'm very amazed about what is happening 😳
I've made a workflow which get the data from Facebook lead Ads and post it on a Google Sheet using the trigger "New lead (instant).
I've selected a specific page that I manage on facebook and specified a specific lead form.
BUT
Checking the workflow history I've just realize that it try to trigger the flow also with data not coming from that specific form.
It try to trigger with woocommerce order (!!!) data which belong to totally another client, which also I manage the facebook page, but it has nothing to do with the previous! The only way facebook can get those data is through the Facebook Pixel, but why Pabbly can get access??? and how to avoid that??
Supreme
Hey @edoardo.bonitti
Kindly share the name of the workflow in which you are having such an issue.
Further, as we can see from your first 2 workflows you are receiving all the lead data in the same sheet. Please review that and do the required changes.
Supreme
As we can see from your workflow's task history Id, it seems like you sometimes get the data from Lead gen and the WooCommerce application.
Please let us know from your task history what type of data you want to process on it. So, we can apply the filter action step afterward so that it will process accordingly.
I want to receive only the data from the fb lead gen that I've specified in the workflow and anything else.
The problem is that those woocommerce event even charge my task on pabbly.
Supreme
If you only want to process the type of data that is already in the trigger response then we would recommend you use the Filter action step.
Kindly try this on your end and let us know if that helps you out.
