problems with google analytics
Hello @Piggy69
It appears that there are no properties under this account, which could be why you're not seeing any options in the dropdown. Please try adding a few properties and let us know if it resolves the issue.
Piggy69
Hi dear @preeti,
The integration doesn't works.
I have Property in place since decates...
Please see that all the time it failed and I don't know why...
It's like Pabbly doesn't recognize my account. :-(
Hello @Piggy69
Thank you for bringing this to our attention. It seems that there have been some changes made to the Google Analytics API, which could be causing the issues you're experiencing. We have escalated your concern to our technical team for further investigation.
As soon as we receive any updates from their end, we will promptly inform you.
We appreciate your patience and understanding.
Hello @Piggy69
Could you please elaborate on the exact use case you are trying to achieve with Google? This will help us better understand your requirements and ensure we move the process in the right direction.
Your input will allow us to proceed effectively and make progress toward the correct solution.
