Quick reply template messages not delivered through Chatflow flow
Private Comment
This field is visible only to staff members and is for their reference only.
Salil
Grant Account Access for Support
  1. I authorize the Pabbly Support Team to access my account for troubleshooting purposes.
WhatsApp Number
8169240327
Email Address
[email protected]
Step 1 - I am triggering initial template messege through pabbly connect and through chatflow action.
this is a template messege with quick reply.
Step 2 - and then subseqent template messeges through chatflow flow.
the flow simply should trigger through quick reply messege.
The first step executes properly but step 2 template messege is not being delivered. flow history shows that its executed but messege not sent.
here is the flow link - https://chatflow.pabbly.com/api/flows/share/690ada6644407dd7c804278f
I have sent the same messege through pabbly connect-chatflow integration - it works. only through chatflow flows its not being triggered.
Hello @Salil,
Upon checking the shared flow, it seems the nodes aren't connected, preventing the entire flow execution. Please connect both nodes to avoid such issues.
Hello @Salil,
We have escalated this issue to our technical team for further review. Please allow us some time to look into it. Once we receive an update, we will get back to you.
Salil
thank you. meanwhile please help me on this.
I want to send a series of 6 template messeges. each one will be triggered on pre configured Quick reply. I am not able to do it in one flow. am i missing something ?
like in above screenshot i want to connect third template to second template. but i am not able to find any connector there.
Hello @Salil,
You can do it all under one workflow. Once the user replies to the template by any of the quick reply buttons, you can add another node to send the next template.
You may refer ot this tutorial for a better understanding of the flow in Pabbly Chatflow:
Salil
I had gone through the video. i am following the steps provided. However I do not see connector in second step (its a quick reply template). PFA screenshot
Hello @Salil,
Please note that in a flow to move forward, we require a user interaction or input, so you may add a button or content under the template node so that the user interacts and then the next template gets sent.
Salil
There is already a quick reply button added in template. Do I still have to add another button in flow ? I want each template to be triggered once user clicks on the quick reply button.
