Required parameter missing or invalid
lcdncodr
Hi im trying to sync the quantity of my products which is the trigger column G to the quantitiy of that specific item on shopify, when i try to send test request and set the quantity to 2 the quantity on shopify also changes to 2, but when i set the quantity to trigger column g it shows an error, what i want to happen is to automatically update the product quantity on shopify based on my google sheet quantity. Thanks
Hey @lcdncodr
Could you please share the URL of the workflow you used, so we can assist you better?
Hey @lcdncodr
Please verify the "Set Quantity To" field, which requires the use of positive or negative numbers, such as 4 or -3. The quantity will adjust to the number inputted.
