Scheduled task is not recurring
partopia
Hey Guys,
My flow is as follows:
1. Trigger - Schedule by Pabbly, Dates of the Month, 14, 11:35 AM
2. Action: send Gmail.
I want it to repeat sending that email every month on the 14th. It used to work but now it has stopped for a couple of months.
Any idea what the issue is?
manthan
Hey @partopia
Upon reviewing, it appears that your connection with Gmail has expired or you may have updated your password. To ensure the smooth functioning of your workflow, please establish a new connection. For further clarification, please refer to the attached screenshot.
partopia
Hey @partopia
Thanks!
Yes, I had updated my gmail password.
I updated the connection in one of the tasks and reconnected the gmail.
Will it auto update in all of the other tasks now since I updated the existing connection instead of making a new one?
manthan
Hey @partopia
No, it will not auto-update in every workflow. To ensure that the update is applied to all workflows automatically, please follow these steps: navigate to settings, then go to connections, and click on the three dots next to Gmail. You'll find the option to update there. Updating from this location will ensure that the update is applied across all workflows. For visual guidance, please refer to the attached screenshot.
