You write Pabbly Connect has "Instant triggers" here:
But they clearly are not instant - so how often do they check in reality?
The problem is I have timetracking entries I send to an accounting app. In the workflow the first time it needs to check if a contact entry already exists and if not, then create a contact there. However Pabbly creates duplicate contacts and duplicate invoices with separate time entries because triggers instead of being triggered instantly, are triggered delayed.
How can I fix this?
And how often does Pabbly check triggers?
This is the workflow: https://connect.pabbly.com/workflow/mapping/IjEyMjUzMiI_3D
Look at these:
https://connect.pabbly.com/task/his...=IjEyMjUzMiI_3D&filter_by_task_data=attermann - IjEwOTUwNzAxMCI_3D
https://connect.pabbly.com/task/his...=IjEyMjUzMiI_3D&filter_by_task_data=attermann - IjEwOTUwNzAwNiI_3D
Despite the entries being 3 minutes apart Pabbly connect doesn't trigger them instantly and instead waits and only triggers these 1 sec apart which causes duplicate issues. Inserting a delay won't fix that either because then each task will both be delayed and still trigger sepArately if there are. So:
A. How do I solve this?
B. How often are triggers checked for (because it is not instantly as your webpage claims)?
Pabbly Connect Automate your business with integrations and tasks 2022-03-18 at 3.40.32 PM
Shared with Zight
share.getcloudapp.com
How can I fix this?
Look at these:
