Twice flow trigger for single activity
Status: Closed · Asked by Joshua Paul on · 0 views
The issue you are describing can occur when you click on the "Save & Send Test Request" button multiple times. This creates multiple webhooks in Google Calendar, which can cause the workflow to execute multiple times for the same event.
To fix this issue, please disable your current workflow, clone it, re-enable the new workflow, and set up the Google Calendar trigger step in the new workflow. Make sure to click the "Save & Send Test Request" button only once while setting up the trigger step.
Hello Joshua,
I hope you’re doing well. I just wanted to follow up regarding our last message.
Adeel Akhtar
🌐 Pabbly.com
Hello Joshua,
I hope this message finds you well. I’m following up on my previous message. Further, this is our last follow-up. This Forum thread will be closed automatically as we have not received a reply. You can start a new thread or email us at support@pabbly.com to raise your concern.
Adeel Akhtar
🌐 Pabbly.com
