Typebot.io - No Trigger
kxkwik
Typebot.io has been listed on the software that can be integrated by pabbly. I tried to connect and there is no trigger at Pabbly. There are two posting previously discussed about this and as far as concern, there is still no comment and correction.
kxkwik
VALUE AT TYPEBOT.....
It really gives me a confusing answer on value.
My bot only collect
- Category discussion
- Name
- Phone number
- Email.
But no fields are mapping.
Supreme
Hey @kxkwik
We have checked the Typebot and it seems like you may haven't captured the webhook response carefully. For that click on "Re-Capture the Webhook Response " and send a sample data from the Typebot application so that the webhook response can be captured successfully.
kxkwik
Thank you for the confirmation. I have successfully mapping again and it works! The mapping process has to be in line with filling the data directly to the bot. Once the bot finished. all the data is mapped.
thanks.
