Using Pabbly Connect to Integrate ThriveCart and Shopify
As the title suggests, I'm trying to use Pabbly Connect to integrate my ThriveCart and Shopify accounts.
In Pabbly, I notive the ThriveCart integration has options for:
  • Orders
  • Bumps
  • Upsells
Does "Order" cover everything in a customer order including bumps and upsells, or does it only cover the main product for the page?
If I have a bump and an upsell, do I need to setup separate workflows for each bump and upsell?
Thank you.
Let's say I have:
  1. A thrivecart order form for Product A
  2. Product B as the bump on that form
  3. Product C as the upsell
I have three seperate workflows, on for each product, sending that data into Shopify.
Does this mean that the customer will have three separate orders inside Shopify?
If I have a second checkout, with different products on it, do I need workflows for each of those too?
ArshilAhmad
Moderator
Please record a short screen recording elaborating on your exact concern. Additionally, try setting up the workflow and testing the scenarios on your end.
