why my workflow becomes inactive itself again and again.?
sonuku
Please check the workflow by named
The secret of universe 👈
ArshilAhmad
Moderator
Hi @sonuku,
Please read Case 2 of this thread, which explains why your workflow gets disabled.
ArshilAhmad
Moderator
Based on your Task History, this workflow appears to be working fine.
The 'Facebook Pages: New Post' trigger application gets triggered even for posts that don't contain a message. Since the response from the trigger step lacks a message, it fails to map in your action step, leading to this error.
Remove the Filter you added to your workflow and replace it with this Filter condition.
ArshilAhmad
Moderator
You encountered the errors in your workflow because you didn't set the filter conditions properly. The screenshot I shared above was for your reference.
I have made the necessary change on your behalf. Going forward please make sure to apply the Filter conditions properly.
If you wish for someone to create a workflow on your behalf, you can hire an expert. I won't be able to assist you in setting up your entire workflow. https://forum.pabbly.com/threads/pabbly-connect-experts-and-consultants.22/
