Why Pabbly Chatflow takes too much for a template Approval?
Status: Answered · Asked by Rajesh Sharma Sharma on · 0 views
I have used another Portal their Template approval is very quick and easy .
Your portal is very slow and seems not reliable many a times
Hi Rajesh,
Thank you for reaching out! We understand your concern regarding the template approval timeline.
Please note that WhatsApp template reviews and approvals are managed by Meta only. Pabbly facilitates the submission and displays the status received from Meta. We do not control or have the ability to expedite the review process. Meta's review may take up to 24 hours in many cases, although some submissions may take longer depending on the review process, which depends on the Meta team itself.
Additionally, regarding your WhatsApp number (+91 8320274494), we checked your separate ticket (TCK-230373) and can confirm that it has been successfully restored and synced in your Pabbly Chatflow account, as we have suggested.
We also checked your three recently submitted templates: shw_nov_3, shw_nov_2, and swh_27nov_1, which were submitted on November 16 and are currently showing as pending review.
Once Meta completes the review, the status will be updated automatically. You can also click Sync Templates on the Templates page to fetch the latest status from Meta.
If the templates remain pending for more than the expected timeframe, please share an update with us. We can then help check and guide you on the next steps. You may also verify their latest review status directly in Meta's WhatsApp Manager.
Thank you for your patience and understanding.
Shekh Dilshekh
Customer Support Specialist
