  • Please note that the team will not be available on 7th May 2024, due to a public holiday.
    During this period, support assistance may experience some delays.
why pabbly connect consumed all my task
abhipatil
i have setup schedule trigger to every 1 minute sent sms for testing purpose.
but when i made the automation it consumed 90 task.
i have given data range as A2:B. i hope it means it will not consider empty rows in b column.
the last column in B row is 11th. then why it consumed 90 task?
abhipatil
the data is in B row. i have left some column empty just to check if trigger skips it.
do you want to add only B or B(last cell number).
i kept only B because i thought it will skip empty cells and move to next one.
Supreme
Hey @abhipatil
We have updated the help text of the Get Rows action step. As you can use the range as A2:D to get all filled rows. D is the last column header of the sheet. Also, ensure that you must have data in the given range.
Further, if you are not passing the end column then you need to pass the definite number to the range to fetch the range till that, otherwise, it will try to fetch all the rows from your Google Sheets.
