WIX webhook trigger not captured, was working
Hi. I use the WIX webhook to trigger sending emails via Postmarkapp. This has been working fine until Wednesday.
When testing I can see that the trigger has been activated successfully when a web form is completed. But when waiting for the webhook response to show in Pabbly nothing is coming through. This is impacting 3 of my workflows which use WIX webhooks. I've check that the webhook URL referenced in both Pabbly and WIX are the same.
Isabel
ArshilAhmad
Hi @partykitnetwork,
The trigger used in Wix is based on descriptive webhooks and captures whatever data the application sends to us. We do not have any control over the data that Wix sends to Pabbly Connect. If the data is not sent from Wix's end, your workflow won't be triggered.
You can try testing this on Webhook.site to see if you are able to capture the form responses there or not.
