workflow not running
Status: Closed · Asked by Vir Singh on · 0 views
Thank you for sharing the details.
Please check the following in your Google Sheet:
Go to Extensions and check whether “Send on Event” is enabled.
If it is already enabled and the workflow is still not triggering automatically, please try reconnecting the Google Sheets connection in Pabbly Connect and test again.
If the issue still persists after reconnecting, please share a screenshot or screen recording showing the Google Sheets settings and the issue at support@pabbly.com. We’ll check it further and assist you accordingly.
its working now
Thank you for confirming that it’s working now.
If the issue has been completely resolved from your end, can we close this support thread?
Since the issue has been resolved, we’re proceeding to close this support thread.
If you face any further issues, you can reach out to us at support@pabbly.com, and we’ll be happy to assist.
