Youtube Upload using Channel ID
Hi. I'm unable to upload a Youtube video to the correct Brand Channel. I have three channels connected to my Account and the Channel I'm trying to upload to is not the default channel for this user. The user does have the rights to upload to the channel in the GUI at least.
The issue is related to the Task "YouTube : Upload Video (Beta)". Tests using "YouTube : Get Channel Stats" it works as it should. It uses and retrieves the correct information from the Channel ID provided ( tried both static string and variable with the same result ).
How to reproduce:
1. Use Task "YouTube : Get Channel Stats" with Channel ID "UCu0jho7Bc7EPF2-6709djng". Results returned is correct.
2. Use Task "YouTube : Upload Video (Beta)" with Channel ID "UCu0jho7Bc7EPF2-6709djng". Upload begins... ( to the wrong Channel ID UCPKOz39RceBbW_IOp2K_z3A )
It only uploads to the connected accounts' Default Channel and not the provided Channel ID.
PS. The Channel ID drop down isn't containing all Channels for the User ( Only the default channel ). What displays isn't the Channel ID either but the name.
Please advise on how to upload to the correct channel.
