Zoom Integration with Pabbly Connect
This documentation offers a comprehensive, step-by-step guide to integrating your Zoom account with Pabbly Connect. By following these instructions, you can effortlessly establish a seamless connection between the two platforms.
How to authorize Zoom in Pabbly Connect?
  • Within Pabbly Connect, navigate to the trigger step and choose "Zoom(Triggers)" as the trigger you wish to perform. Select a trigger event, such as "Configure Webhook".
  • To establish a connection, select "Add New Connection" and if you already have an existing connection, you can opt for "Select Existing Connection" instead.
  • To establish a new connection, select the "Add New Connection" radio button, and enter the Token.
  • To obtain the "Token", log in to your Zoom account. Navigate to the left sidebar, go to the "Advanced" section, and click on the "App Marketplace".
  • To create a new app hower on to the "Develop" button and click on "Build App".
  • Copy the Secret Token and go to the Pabbly Connect connection page, enter the Token here, and click on "Save".
  • Copy the Webhook URL and go to the Zoom App Marketplace, click on "Add New Subscription" button and click on edit button.
  • Enter the subscription Name and choose the Events and paste the Webhook URL in the Event Notification Webhook URL field and click on "Save", and click on "Continue".
  • Click on the "Add App Now" button to add an app to your Zoom account, and click on Allow and our app is added to our account.
  • Go back to the Pabbly connect and click on "Save and Send Request" button.
  • Click on "Schedule Meeting" now enter the meeting details, and click on "Save".
===========================TRIGGERS============================
Zoom: Configure Webhook(Action Event)
Please follow below the steps for the above-mentioned trigger event:
  • Use Case: To capture the response of the Zoom triggers.
  • Select the "Configure Webhook" as a trigger event, connect your Zoom account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Zoom in Pabbly Connect?" section.)
  • Click on "Save and Send Test Request".
Successful Integration:
Upon completing the above steps, your Zoom account will now be successfully integrated with Pabbly Connect. You can utilize different actions and triggers according to your purpose. With this integration, you can automate processes through Pabbly Connect, improving your workflow and enhancing your productivity.
If you encounter any issues or require further assistance, feel free to reach out to our support team for help. ([email protected])
Happy integrating!
