ActiveCampaign: Not seeing all automations when I use "Add Contact to an Automation"
C Spencer
SOLVED: I mapped the step and entered the ID number for the automation. It seems to be working now. I'll update again if I run into more problems.
I've clicked "refresh to fetch new items" and updated the connection to AC (url and api key) and I still can't see the full list of my automations. There are a lot of automations missing from the list, so many it seems like it's never had the full list.
I also tried mapping the step and entering the automation name manually, but that didn't work either.
Hey @C Spencer
As per the Active Campaign's API documentation, the drop-down can only take up to 100 automation in the list.
Further, you can map the automation ID to Create a Contact by retrieving the Id with the help of "ActiveCampaign: List All Automations a Contact Is in".
