Can - Text formater : Split based on 2 values? A or B?
Pabblynaut
Can the Pabbly text formater be used to split both strings below?
Text to Split: # OR &
apples#bananas
peaches&apples
Wanted result:
bananas
apples
Any help is appreciated!
Supreme
Hey @Pabblynaut
You can use 2 Text Formatter action steps in your workflow to split the "bananas" and "apples". Please check the following screenshot for your above concern.
1-
2 -
Oleksandr
Hi everyone,
What would be the correct way of using the text formatter to convert 09:00:00 to 09:00? I tried splitting the ":00", but in this case, it returns 09. If the time is 09:15:00, 09:50:00, 09:30:00, etc - it works, because it takes only the last 2 zeros, but I can't figure our how to get rid of the seconds. I tried using ALL of the available segment text options with :00, but so far, no luck...
Supreme
Hi everyone,
Please refer to the following screenshot for your concern.
